Need a Lil advice guys and gals
So I've got a 95 cobra block and stock bottom end,but I've got holly aluminum heads dressed out with 1.7 rockers,titanium valves and double springs,and I bought an Anderson b-31 cam,windage tray,gt40 upper and lower,80 mm tb and 36#injectors with mass air conv,also bought a vs-1 's trim vortech with around 13psi..but my quest is will 1.7s work will the Anderson b31 cam..thanks yall
This is a nice stick. Used it on a 450 hp 308 With a 150 hit of nitrous. I would stay with the 1.6 rockers. 1.7 will make the cam think it is bigger, but it might be to big for your application. Try the 1.6 first, if you feel you need more cam, try the 1.7.
Sounds like a good build. |
