Speedo gear
Speedo gear
67 coupe Mustang
302
C-4 auto transmission
I drove my car last summer and noticed that the speed was off. I have changed the rear tires. Since then I have tore apart the dash and replaced it. I was playing with the speedo cable, gauge(reset the miles) and took the cable out of the tranny to see what gear I had.
I have the dash/speedometer in speed cable hooked up. The cable into the tranny but now the speedometer doesn't work? I take the cable out of the tranny and spin the gear and the speepometer works. I look into the hole where the speedo gear goes and I can see the little gear turning when I turn the tires. I install the gear and nothing?? I thought that I was turning the tires too slow so I put the car on jacks and ran it..Nothing
Does anyone have any ideas?
302
67 coupe Mustang
302
302
When you looked into the transmission, did you use a light to see if maybe the teeth on the gear inside were chewed up? If they are, it is easy enough to remove the driveshaft, then the tail housing (transmission must be supported off it's mount), and the gear removed from the shaft. There is a snap ring which keeps it in place, and a steel ball in a pocket in the shaft which drives the gear. If turning the cable makes the speedometer needle move, the trouble is in the two gears somehow. If you determine the need for a new gear or gears, and you have installed different diameter tires than original stock, I can tell you how to determine how many teeth each gear needs to have. Just ask. imp
At this point I have not replaced any gears. The speedometer was working up untill I replaced my dash and unplugged the cable from the tranny. The gears don't appear to be chewed up.
Is it possible the gears are not lined up? the little clip is still attached on the speedo gear.
All is good. I reseated the cable behind the dash. Reinstalled the cable in the tranny. Seems to be working.
Another question thou...My speedometer is out. Doing some reading and using the calculator. Seems easy enough. Except how do I know what drive gear I have in hte tranny? Lots of Forums just assume # of teeth.
I would like to get the speedo correct. Can you help me determine what drive gear I have?
