5R55 S Transmission Cold start Valve delete
Mustangs 2005-2009 V6 and some GTs idk for sure are equipped with the 5R55S transmission has anybody heard of the Cold start valve delete for a full transmission fluid flow ? http://www.explorerforum.com/forums/...r-flow.338261/
I have heard that this is good to keep your transmission cooler now it serves the same purpose as a thermostat to not let cold fluid go into the engine and not let cold transmission fluid go where it shouldn’t until it’s hot but I live in Florida everyone knows the cooler it gets out here is 60 degrees. For like a week has anyone else done it? I already took my transmission apart I burned my forward clutches for reasons I don’t want to discus lol just let me know if you or anyone you know has done it and what they think about it or just give me your honest opinion should I do this ?
there won’t be any time or effort involved in this mod because like I said my transmission is already out and taken apart. But thanks for your opinion man
One method is to reverse the order of the parts and the spring inside so that it is always in the 'Open' position.
This is the write up from Level 10 on the cheapest method:
The other is to buy a shift kit like one of these that have some parts in them that also keep the valve in the open position.
I bought my kit, solenoid pack, and filter kit from these guys. Killer customer service and quick to answer my questions. I was having a hard time deciding which kit I wanted so they were kind enough to scan the instructions to me so I could decide for myself.
This one here is more complete if you're dropping the tranny as it has parts for the pump and for the return springs in 3-4 drum. I ended up buying this one but never used the springs for the 3-4 drum as I never dropped the tranny.
https://www.cascadetransmissionparts...ectionkit.aspx
This is more a valve body only kit but it does have some stuff for the cold start valve and the pump.
https://www.cascadetransmissionparts...wshiftkit.aspx
