Sponsored by:
Sponsored by: DashLynx
Cervini's hood without hood pins?
Old 10-06-2018, 05:25 PM
ricky914
ricky914's Avatar
Default Cervini's hood without hood pins?
I recently purchased a Cervini's Ram Air Hood Part #1211 for my 2014 GT. I like the way the hood looks WITHOUT the hood pins. Has anyone installed this hood and used it without the pins? I called Cervini's and asked them about it and they said that as long as the hood is securely installed with the factory hardware, I "shouldn't have any problems." I don't race the car but I do drive fast and love to hammer on it when I get the chance (it dyno'd at 637 RWHP). I've looked at both options, the general placement pins and the radiator bracket pins and I don't really care for either of them. Thanks.
ricky914 is offline
Old 10-06-2018, 10:37 PM
08'MustangDude
Banned
08'MustangDude's Avatar
With metal hoods:
Hood pins are for show, they don't effect the secure latching of the hood. It used to be,
the hood pins were used in lieu of the latching mechanism to hold down a fiberglass or
stripped out (no braces) metal hood on race cars, since there was no latch or springs
because of weight savings.
Aftermarket hoods:
Carbon Fiber, and Fiberglass hoods are much lighter than the Aluminum ones. They
are prone to air-lifting on the drag strip, so the hood pins are to be sure the hood does
not fly up should the latch fail under the stress of being pulled on. Factory hoods are
aluminum skeleton, aluminum hood, with the steel striker bolted through it. On some, the
striker is bonded to the fiberglass, or carbon fiber hood. Over time, the striker can become
weak or even come loose, then the hood pulls off it, leaving the striker in the latch, as the
hood flies off, or in your face... Then there are others that have a place to bolt your striker
on to the hood, but it's not going into a metal fame.
Hood pins will make sure that does not happen, and even some warranties state you need
a secondary latching system, or they void the warranty if it flies off, and definitely not if it
just came out of the latch and flew up, or off.
Some, very few, aftermarket hoods, that is the only way you can latch them, is with the hood
pins.
08'MustangDude is offline
Old 10-07-2018, 01:47 PM
Moderator
JimC's Avatar
Aftermarket hoods:
s.
Fiberglass is definitely NOT lighter than the aluminum stock hood. I had one and the weight difference was huge. Every fiberglass hood is heavier.
Carbon fiber may be lighter, but not all of them. Some weigh the same, or more, than stock aluminum.
JimC is offline
Old 10-07-2018, 02:16 PM
08'MustangDude
Banned
Oh well, so much for you-tube...
Old 10-10-2018, 12:33 PM
Z28KLR
Z28KLR's Avatar
There are numerous fail stories out there regarding aftermarket hoods flying up at highway speed. It is usually attributed to a structurally weaker latch area (vs factory) on the hood, but any bit of misalignment or improper install or fitment related thing can be the culprit too. I'd look into some pins or additional latches just to be safe. There are some flush-mount latches out there that are pretty nice.
Z28KLR is offline
MRich44
01-10-2013 01:31 AM
stevenc1010
09-24-2008 03:06 PM
DoctorD415
02-05-2008 08:19 PM
nacanitihs
07-21-2007 09:20 AM
LEVINEMN5.0
05-06-2007 04:33 AM
Quick Reply: Cervini's hood without hood pins?
