Leak in trunk
Hey was wondering if anyone else had this problem I have a 2006 ford mustang gt convertible i took out the stock subwoofer in trunk and there was water on both sides of the trunk. And there was a little in the middle under spare guessing that's from swishing around from side to side. Any info on where this thing could be leaking would be awesome thanks.
The spare tire well is actually the low point, water will end up in there almost no
matter where the leak is. I would check the tail light stud seals; where it fastens to the body of the car. If you have a spoiler; opening and closing the trunk using the spoiler as the handle, flexes everything, and water can get in through the mount holes, as it runs down the trunk lid. Then the only other way is a crack or hole in the water channel, the area below the trunk seal, where all the water runs into, and down to, and behind the tail lights. |
Thanks man ill check it out tomorrow i appreciate it.
