Where are MAF and O2 sensors? P1131, P0171 troubleshoot.
I have P1131 and P0171 Check Engine codes on my 98 Mustang (3.8). This is what I found out browsing around:
P1131 - Oxygen Sensor Lean *codes* A U
P0171 - Oxygen Sensor System Too Lean Fault Bank A
So, I decided to clean the IAC, MAF and O2 sensors. If that does'nt help, I am planning to replace the O2 sensors. Problem is, I am trying to figure out where the MAF and O2 sensors are located.
I noticed that in the air duct that connects from air filter to injector before IAC, there were two sensors.
This is the first sensor:
which I got from the area I have marked "1". Wonder what this is?
I think I have identified the IAC correctly.
At location "2" I found this:
Can someone kindly help me locate where the MAF and O2 sensors are?
Any kind of guidance appreciated. Thanks.
[IMG]local://upfiles/24082/74999B6A337341C1AAB8C1CDD1AFCAC1.jpg[/IMG]
[IMG]local://upfiles/24082/A6F01447051D4F0DB05E373337C7B3AB.jpg[/IMG]
[IMG]local://upfiles/24082/0FF1A52D6F87431FA4E7DD53B3197BB1.jpg[/IMG]
RE: Where are MAF and O2 sensors? P1131, P0171 troubleshoot.
Are the O2 sensors these then? I was looking for some sensor with four wires coming out. I am also surprised that whatever "4" is has only 1 wire and seems like another wire is cut/missing??
[IMG]local://upfiles/24082/BB5B4B1330FB4A1998213E27DC1F0A8F.jpg[/IMG]
Start at your exhaust manifold, and follow them back. You will see the O2's along the way. Change them all. You might have 2 or 4 depending on the year. If one failed, the others aren't far behind.
#1 is the air temp sensor. Your car should have four O2 sensors - one on each bank prior to the cat and one in each bank after the cat. The pre-cat sensors are tough to get to, but it is do-able.
Gary
Gary
