MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   General Tech (https://mustangforums.com/forum/general-tech-6/)
-   -   Won't Idle (https://mustangforums.com/forum/general-tech/80002-wont-idle.html)
86GtCobra Dec 7, 2005 01:51 PM
Won't Idle
Just had to put a new engine in my car, put my intake and throttle body on it, it's timed to 10 degrees, but it won't idle, as soon as i take my foot off the gas it stalls, WHAT ARE SOME THINGS TO LOOK FOR THAT WOULD CAUSE THIS SHYT !!!
Tim37 Dec 7, 2005 01:55 PM
RE: Won't Idle
new engine?
what do you have in your new engine?
86 was speed density efi and it doesn't like mods if you did any thing more than a very mild cam or mild heads it will cause the car to not run right.
give us an idea of what you have and maybe we can help ya a littel.
86GtCobra Dec 7, 2005 02:02 PM
RE: Won't Idle
I Stupidly took a 5.0 out of a 1990 Lincoln only thing i did was put my the stock 86 intake and throttle body on it and stock 86 headers
Tim37 Dec 7, 2005 02:04 PM
RE: Won't Idle
ok isn't what i first suspected
i would start buy trying to adjust the idle ajustment screw see if that will do it if not then look for a vacume leak.
86GtCobra Dec 7, 2005 02:04 PM
RE: Won't Idle
put that engine in cause it had 150 lbs straight across 80,000 k and was $500 my crank busted in half in the original 86
86GtCobra Dec 7, 2005 02:07 PM
RE: Won't Idle
Quite the Frankenstein contraption eh Tim, idle screw on E.F.I. ???
Tim37 Dec 7, 2005 02:12 PM
RE: Won't Idle
yeah there should be one on the throttle body.
86GtCobra Dec 7, 2005 02:14 PM
RE: Won't Idle
right on thanx tim i'll give er a try tonight when im off work...
Tim37 Dec 8, 2005 01:03 PM
RE: Won't Idle
just wondering if you got it running?
© 2026 MH Sub I, LLC dba Internet Brands
