where to jack up a 03mustang
#21
RE: where to jack up a 03mustang
ORIGINAL: 03YellowPony
Just as long as you lift inder the dif housing, and don't get under the dif cover, it's ok.
ORIGINAL: StickShiftyGT
ive been told both, its fine and bad to lift from the diff. i never do it, i just use the four jack piont cut-outs in the uni-body. works fine.
#23
ORIGINAL: Tim37
true like i said the rear housing is strong enougth but i have messed up a diffy cover and had to rea seal one. I HATE MESSING WITH REAR END GREASE THAT CRAP STINKS.
#24
ORIGINAL: redass02gt
hahaha
ORIGINAL: Tim37
[sm=owned.gif]
#27
ORIGINAL: 95_302_StangMan
All you need is a skrewdriver, unless your afraid of a little gas getting spilt, btw I would where some saftey goggles if you do.
http://www.mytoolstore.com/astro/asthan13.html
#28
ORIGINAL: Derf00
You've never worked on replacing the fuel filter on an 99-04 mustang then. Screwdriver will get you no where because the release for the filter is INSIDE the fuel line and you have to have a tool to disconnect it.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
09-17-2015 07:57 PM
