Should Synthetic oil be cleaner than reg after oil change?
Old 01-08-2006, 10:19 PM
NewMexMustang
NewMexMustang's Avatar
Default Should Synthetic oil be cleaner than reg after oil change?
Since they are engineered shouldn't they not be as dark as regular oil after an oil change?
NewMexMustang is offline
Old 01-08-2006, 10:37 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default RE: Should Synthetic oil be cleaner than reg after oil change?
I've never noticed a difference in the color when I changed synthetic vs conventional.
Dan04COBRA is offline
Old 01-08-2006, 11:14 PM
NewMexMustang
This past time was the first time I used synthetic (Valvoline SynPower) and I though it looked really dark compared to past changes...didn't really go over 3k either.
Old 01-08-2006, 11:24 PM
sprostang
I ♥ Acer
sprostang's Avatar
They both should look the same.
sprostang is offline
Old 01-08-2006, 11:26 PM
Chopper
Chopper's Avatar
Most of the black color comes from carbon and not metal so there would be no real difference in oil color.http://www.bobistheoilguy.com/ this link has just about every answer to every question to do with oil.
Chopper is offline
Old 01-09-2006, 01:56 AM
NewMexMustang
so what would it mean if there is an unuasually large amount of carbon getting into the oil?
Old 01-09-2006, 03:29 AM
OnyxCobra
OnyxCobra's Avatar
prolly just that the synthetic oil is doing a better job at cleaning ur engine... sorry misread, unusually large amount of carbon might be a different story, maybe u have a bad ring?
OnyxCobra is offline
Old 01-09-2006, 03:54 AM
NewMexMustang
dang well hopefully not, but keep a close eye on the oil this 3k and see how fast is degrades...hopefully I'm just being too worried
Old 01-09-2006, 03:58 AM
Black Snake
Black Snake's Avatar
If your going synthetic get royal purple, it proved to improve HP, in a show called HorsePower TV
Black Snake is offline
Old 01-09-2006, 01:10 PM
Tim37
Tim37's Avatar
the diffent color may be the diffent detergents and conditioners in the oil its not uncommon for that to happen when changing brands or types of oil. the color should return to normal after a oilchange or two.
Tim37 is offline
Quick Reply: Should Synthetic oil be cleaner than reg after oil change?
