Please help me w/ my cold air intake mod
I'm trying to change from the stock rubber cold air intake pipe into the aluminum pipe on my '99 V6 stang. I've installed everything except for the air filter which needs to be installed from underneath the fender, but I'm not sure how I am suppose to do that from the looks of it. Am I suppose to take off the front end (bumper & fender) in order to intall the air filter? Here is the website generic version of the installation manual http://www.mustangtuning.com/mustang...-gt-cobra.html. I thank you for all the help and your time.
RE: Please help me w/ my cold air intake mod
no don't try to take the bumper off
get the car off the gound a little then crawl under it there shoud be enough room in fornt of the right front tire you should be able to access the filter tube form there just reach up and put the filter on.
I have a Mac cold air that i installed. I had a hard time with the filter also. I used a cordless screwdriver, flashlight and bent the black plastic guard with no damage to it under the front passenger side so i can get my arm into the fender. The powered screwdriver helped alot to tighten the clamp onto the filter and pipe. Good luck.
https://mustangforums.com/m_757359/tm.htm
Go to the link. Booze made a step by step post on installing the CAI through the fender well.
The power from a CAI is mostly because it sucks more in. Also put a little vasoline on the filter it will slide right on. BE sure to wipe it dry after its on though.
this is the route i went when i installed mine. it worked perfect.
ORIGINAL: 03YellowPony
09-01-2015 08:16 PM
