T5 Transmission Bellousing and ID
I am looking at a T5 Transmission and Bellhousing on Ebay, two questions?
The seller does not have the ID tag for the transmission, but does have the transmission case #. Can you identify the transmission using the case #? 1352-965-908
Second, this transmission and bell is out of a 1992 5.0 Mustang LX. Will the bellhousing bolt up to a 1998 5.0?
Thanks
Thanks
RE: T5 Transmission Bellousing and ID
98 5.0 if i remember right the only thing that a 5.0 came in 98 was a explorer. other wise its a 4.6L if you have a 5.0 yes it will bolt up if its a 4.6 no it won't
im not sure on the id number.
Second, this transmission and bell is out of a 1992 5.0 Mustang LX. Will the bellhousing bolt up to a 1988 5.0?
Thanks
My mistake, I meant a 1988 5.0....
Thanks
oh yeah if it is out of a 92 it will bolt up to a 88 with no problems.
edit: what confused me was the 66 in your sig i didn't know what if the motor was going in it. i have seen a few of those cars with 4.6's so i wasn't sure what direction you were going.
that case number means nothing.....
it is the same though bellhousing-wise.
i would like to know why he doesn't have the id tag though??? is it a 4-banger t5? someone had it apart and didn't put it back on ? why was it apart ?
i might stay away.
1985-1993 all will work....1985-1989 rated at 265 ft/lbs and 1991 up are rated 300 ft/lbs
i might stay away.
