Coil overs
RE: Coil overs
So far, Tein Super Streets and H&R are all I've seen. Tein Flex are in the works.
The Tein SS would be fantastic, but the problem I had with them was the drop is around 2" at it's optimum, so I went another way. They would be harsher than all other apps for the Mustang but totally streetable. My last car had JICs with pretty much the same spring rate but weighing almost 1000lbs less than the Stang and it was only a burden on old craggy pavement in the downtown areas. I would recommend at least a rear sway upgrade as the 4kg springs might be kinda light in the corners.
jaiidutch
09-14-2015 10:29 AM
