?tire size type??TIRE PRESSURE
RE: ?tire size type??TIRE PRESSURE
ORIGINAL: Stoenr
After a ride today I was just thinking. It's not a bad idea to run with a few extra pounds if you live in a pot hole prone city. Rims and tires aren't cheap!
ORIGINAL: Stoenr
I was just talking to a guy at work on Thrursday about something he saw on the number of new potholes in Chicago's streets everyday. I was thinking he said they said like 2800 per day or something like that.
Shawn
Yeah, Im in the suburbs and its bad. Im on a side street and its not that old and is littered with pot holes right out of my driveway. None bad enough to damage a tire/wheel or suspension, but annoying none the less. Also all the loose garbage I hear smacking my wheel wells and Im sure the rear lower portion of the quarter panel when I drive down the street.
Sticky tires are part to blame, my winter beater with skinny snows doesnt pull any of the ashphalt into the wheel wells.
Sorry, got off topic
Stoenr
I noticed that youquoted meintending to disagree but your recommendation is consistent with mine
I said :
I would probably be in the 36psi vicinity and tune it up or down from that point.
35 to 38 F/R for the sizes you mentioned. And dont go with a 285/35/18.
I also mentioned the higher tire pressure I RUN was due to the fact that I like to slide the car sideways alot, (check drifting link below).If you hit an imperfection in the road while sideways and only running 32psi, the sidewall will roll inward and you will rip the tire off of the wheel, (I've done it twice). I also get metterMPG athigher pressures, (less rolling friction).So drifting and MPGwould betwo more reasons you can add to
No reason unless you are hauling a max load in the car, or want to sacrafice traction.
NorthAmericanTuning
11-09-2016 11:44 AM
09-02-2015 07:54 AM
