Weight of Mustang
RE: Weight of Mustang [2005 GT Premium = 3471.8#]
V8 2005 Mustang GT Premium 4.6L 3V 5 speed Automatic w/ OD. 4655 mi. Pirelli (PZERO NERO) P235/55 ZR17 98 W m+s all around (W= 168 mph) 32 psi x4 per door jam ; stock throttle body: It is a twin 55 mm aperture; K&N Air charger # 63256 using 93 octane BP/Amoco.
Predator U7140 Performance tune. version: stang_05-8r28 12/22/05 3:14:12 PM
Shaker 1000 (see pic of Base in trunk). Wt = 3471.846 # + people + gas @ 5.67#/gal. + luggage/junk
i feel pretty confident (iff the scales at the Dekalb Co Waste Processing plant in Chamblee GA are accurate) the above car === 3471.846 # + gas (5.67 #/gal) + driver and passenger + junk in the trunk. The door says 4550 or 1078.154 too heavy.
4702.7 mi fillup
4705.7 mi dump
3.000 mi driven
14.7126 avg mpg
0.204 k gal
0.2 u
5.67 # / g
1.156152557 #
16.545 max g
16.341 g in car
92.65399744 T. # gas in car
255.5 241 + 14.5 driver + junk
3820 gross wt @ dump
3471.846003 wt = empty car (ok, it has jack, spare tire, etc. just no junk from house)
1078.154 error
4550 GVW + Shaker 1000 = K&N Air Charger
2170 front door
2390 rear door
4560 front + rear
180 adult + luggage
[IMG]local://upfiles/31840/429D110A79044A2E95952D567AEA9B7A.jpg[/IMG]
4702.7 mi fillup
4705.7 mi dump
3.000 mi driven
14.7126 avg mpg
0.204 k gal
0.2 u
5.67 # / g
1.156152557 #
16.545 max g
16.341 g in car
1078.154 error
2170 front door
2390 rear door
4560 front + rear
180 adult + luggage
seriously i weighed mine at the track a couple weeks ago. 3345#(w/o driver) with the spare tire in and 1/4 tank of gas. that was with all my new stuff including drag wheels on the car. i have taken about 200lbs off the car.here's the weight loss from old items vs. new.
k-member=40lbs arms=15lbs. sway bar delete/radiator support=40lbs. bogarts and m/t's=100lbs. driveshaft=30lbs.
the stock weight of 05-06 gt i've read is 3450# w/manual trans and 3500# w/auto trans
the shaker 1000 weighs an additional 85 lbs, i think side airbags are 45lbs. extra also.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
