Tri-ax shifter
Tri-ax shifter
I recently put a new tri-ax shifter on my 06' mustang. I followed the directions exactly when installing it, but for some reason it is a lot harder to push to the right to go into 5th or Reverse than to push to the left to go into 1st or 2nd. #rd and 4th are also fine. I was just wondering if anyone else has had this problem, and if so how they fixed it or what they might think is wrong with it.
RE: Tri-ax shifter
Ha i just basically posted the same thing two days ago.
https://mustangforums.com/m_1156816/...tm.htm#1157974
Basically i was told that its just how it is and theres nothing really to do to fix it.
RE: Tri-ax shifter
I guess I wasn't as clear as I thought I was, I meant that it goes into gear fine (1st - 5th and reverse). but it is just harder to push to the right than the left in the neutral position. And what nut did you mean exactly that I should loosen up, I know you said the shift **** but I dont really know what you are talking about.
junior04
09-28-2015 10:53 AM
09-16-2015 07:53 PM
