hood dance
Old 03-31-2006, 11:54 PM
blackout
blackout's Avatar
Default RE: hood dance
Yeah, absolutely no problems in my 06 but if that happened to me I would definately invest in some hood pins.
blackout is offline
Old 04-01-2006, 12:18 AM
Stone
Stone's Avatar
Find some hood pins that you like there are a few styles out there and they can look very nice on the 05/06.
140+ Stock, smooth as silk I was very impressed.
Stone is offline
Old 04-01-2006, 01:12 AM
jbailer
jbailer's Avatar
That's exactly it. I noticed when I was replacing my hood that Ford didn't properly adjust the rubber stops. You just need to raise those up to the propper height. You'll figure out where that is when it's supporting the hood (keeping it from shaking) but it doesn't make the hood stick up above the fenders. You might not be able to get it to stick up that high and latch too anyway. -Joe
ORIGINAL: Tik_Tok
I raised the rubber stoppers on mine, makes it tough to close (I have to push it down from about half way up) but no more hood shake.
jbailer is offline
Old 04-01-2006, 12:57 PM
Philostang
Philostang's Avatar
That's interesting...the rubber hood stops I mean. I have an 06 (built early enough to have come with an aluminum hood), no issues with the hood at high speed, and yes it is difficult to close the hood. Since this is easier to test than drilling holes or installing hood pins, seems like you should start there.
Best,
-j
Philostang is offline
Old 04-01-2006, 01:17 PM
lost in kuwait
lost in kuwait's Avatar
did even think of the stops my friend just put hood pins on and we had hers up to 240 kph it drives great but it lowerd has toyo t1s and asteeda chin spolier thanks for yalls replys
lost in kuwait is offline
Old 04-01-2006, 02:48 PM
RStone13
RStone13's Avatar
Put some chauk on the top of hood stops. close hood and then open & look on hood liner for marks
if no marks you need to raise the stop
RStone13 is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
11-18-2015 01:34 PM
Urambo Tauro
10-05-2015 09:37 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: hood dance
