How Much To Get ... Installed
Hey guys,
Alright, I don't want to get ripped off, so how much should installation of the following parts cost? I know I should do them mostly by myself but I just don't have enough time.
Borla Cat-Back Exhaust - $?
Nitrous Wet Shot - $?
Diablo Tune - $?
3.73 Gearing - $300?
UDP - $?
Thats all for now. :-) I want to run up my credit card bill this month.
~Fred
Diablo Tune - $?
UDP - $?
~Fred
RE: How Much To Get ... Installed
For installs your probably looking at
Axle back- 50-125
Diablo - 35-100
UDP - 100-250
Gears - 200-400
depending on shop, hours, and equipment used. Also something to consider is buying it all from one place and then having them install it as well. They could cut you a big break on install/labor that way.
Axle back- 50-125
Diablo - 35-100
UDP - 100-250
Gears - 200-400
Well, you will need a Diablo Predator or other tuner to use as they are car specific. $350 to $400. Then if you want a custom dyno tune, you are talking $250 to $400 depending on the mods, how many pulls and just how "custom" you want the tune. If they are only tweaking the A/F then yea, $50 or so, but heck, go for the complete tune. Mine was $400 with 7 pulls and worth every penny. It depends on how many mods you have as well. Gears, labor only, in the $200-$250 range. If you go nitrous, a custom tune is probably a very good idea to consider.
09-10-2015 08:39 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
