I have problem whith my Gt premium mustang
Hello. First to salute by the pagina Web, I am called Jose I write the mail from Spain sorry my english if it is not understood I have mustang GT premium V8 of year 2005 and my problem is that it does not accelerate starts up when starting but I cannot accelerate the diagnosis computer says I cosay P2112 and the failure is acceleration butterfly please forced failure aid in Spain nobody knows east car. thanks
RE: I have problem whith my Gt premium mustang
Best I can comprehend is that your car has gone into fail safe mode. Disconnect the battery cable for a few minutes and then reconnect it. In fail safe the car will not come off an idle. Did you do anything like try to download a tune or add a bolt on? If not, and it happened out of the blue, there is a problem that caused in to fail safe. Let us know if the reset works.
I am still not certain what you are saying as far as if you tried to load a tune. If you did, try to reload it, making certain that no accessories are on, follow the directions EXACTLY and do not open a door while downloading. Immediately after reloading, disconnect the battery again. That happened to me once. Someone opened my passenger door while I was loading a tune and everything went south. Reloaded and disconnected the battery and back to normal.
Hello, I and disconnected battery and when the e connected and touched to nothing despues again I do not open the door of the conductor and enter within the car and I connect the ignition and I take the then motor and it says computer to me FAILED SAVED EMERGENCY and the car does not allow to accelerate the motor
Hi Golforone,
The error you obtain is P2112¿? I don't have this code in the list of possible codes!¡
Regards
I'm from Spain also. If you can, we can speak about your problem in private mode.
Regards
Que lastima. LLeva lo por donde lo comprastes. Tiene garantia no? O no hay dealer de Ford en Espana?
What a shame. take it back to where you bought it. It has a warenty right? Or are there no ford dealerships in spain?
