Front license plate mounting
Hey, everyone. I have a new 06' GT, and just got my license plates. Since my state requires front plates, I guess I will put mine on. Is there any trick to it? The holes haven't been drilled yet, and all I have is a cordless screwdriver. Can I just use that to put the screws in? I'm sure everyone is going to say don't bother with the front plate until I get a ticket, but I don't think it's too bad to put it on. Thanks.
RE: Front license plate mounting
Whatever dealer you bought the car from should do this for you. If you bought the car out of state, then whatever Ford dealer you plan on having service your car should do it for you.
I wouldn't put holes in the bumper but if you must, there are two tiny dimples (slightly visible) behind this is a molded plastic bumper material sleeve to accept the screw. Use stainless phillips (no more than 3/16 diam" I'd use first) and any screw driver.
I like the magnet idea one guy had; I would just add a wire or two in case it ever came dislodged; but NO HOLES; I don't have front plate in MA (newer red plates are two; older green is one)
Here in Cali its not absolute law, for people like me, its really just a suggestion at this point. I don't have mine on, the dealer never put the holes in for me. And if I get pulled over for it, its a $10 fine, and a fix-it ticket. So, I go home, get the plate, double side sticky tape it on, and go and get it signed off.
ORIGINAL: hottymustang
I saw some guy on here that made an "L" type bracket that mounted on an underside of either the bumper or lower air scoope thing, so at least the holes were not visible. That seems like a godd idea.
PA does not even issue front plates! [sm=smiley4.gif]
I make a bracket that bolts on from the top of the lower opening. E-mail me for details.
http://i36.photobucket.com/albums/e4...nsPlate003.jpg
http://i36.photobucket.com/albums/e4...nsPlate002.jpg
Easy Removal for shows.
ORIGINAL: chevykiller
+1 - I have the roush front fascia and I have not had a front plate for over a year and have never been hassled for it.
maestro1024
09-21-2015 02:40 PM
09-16-2015 07:53 PM
