Saleen Supercharger for my GT
hi guys, i'm thinking of adding a Saleen Supercharger on my 06 Mustang GT. i found it on Ebay, and according to the seller, no other upgrades are needed to have it install and the stock car can take it, but doesn't someone agree with me that at least the headers/pipes should be upgraded to take the boost power out?
regards
[IMG]local://upfiles/36246/3E0ECF0EDDCB4D7CA66A921443720642.jpg[/IMG]
regards
RE: Saleen Supercharger for my GT
From everything that I have read on this forum the one thing people almost always upgrade with a sc is to go with 39# injectors. I think you may also need to at least regap your plugs or get new (cooler) ones but someone else may want to comment on that.
That kit comes with all the fuel and tuning you need i believe. You can leave the car stock but its not recomended. Probably should upgrade your drive shaft who knows how long the 2 pieces will stay together with 400 450 hp. Exhaust is must with any car that is supercharged or turbo. Got to let her breath. Also with that kit you might need to get a new hood with a little more cowl, so you might want to look into that.
Kit should have everything you need. You do not need different exhaust, KB was pushing like 500+ HP with the stock system. As far as I have heard the Sallen SC do not push much over 400HP.
ORIGINAL: cableguymicah
I ve got the saleen s/c on my saleen and im putting 401 rwhp. The dont require it but you need to upgrade the injectors. Everything else is there
Thanks for any info
I have the stock n/a saleen hood which is the same as the Gt hood. No need to upgrade there.
You go to remember Saleen does not upgrade the driveshaft on the Saleen S/C cars so I dont think you will need to either.
I will also tell you this what ever s/c or turbo you go with, the bottom end of this engine has known to blow with to much boost and hp. Unless your going forge internals etc, be sure to know that you are at risk at your engine going bye bye. There are plenty of post on here about that.
Saleen s/c gets you plenty of Hp with little boost which in return is better on your engine.
the saleen tune is dangerously lean!...get the39# injectors and a quality dyno tune
My mech. is working with saleen and he said they will start offering upgraded SC kits with fuel pump and injectors in the near future
ORIGINAL: Airborneflyguy
ORIGINAL: jassem
ORIGINAL: jassem
ORIGINAL: Meangreen1200
