It's official, UPDATED
RE: It's official, I have the....
ORIGINAL: stang9325
Yeah, just try shifting a little higher each time until you notice your ET's beginning to fall. The 2-3 shift is a critical part too (which you obviously know with your experience). Keep trying things until something works for you, you'll get it!
ORIGINAL: cableguymicah
Since you didn't have it dynoed tuned then thats probaly where you problem is more than likely.
though every car is different try shifiting at 5800 rpms if you haven't already, maybe you want to launch around 2800 or 3000.
Keep it up, though 13.8 isnt that bad you should be able to cut to 13.4-13.6 with a proper tune.
Shifting it at 5800 gave me the worst result, I think the re-tune and higher shift points should work.
Hey guys, you hanging third to almost the end or all the way? I nail 4th very close to the end of the 1/4 simply because it feels like it needs it... The launch isn't that bad at around 2200-rpm's which has gotten me 2.1 60foots.
ORIGINAL: Lucy2005
If the 05 was stock, you are probably not far from where you should be. Drag Radials will make a huge difference, but remember, track conditions, the particular track, etc. makes a big difference. At my track (Bristol, TN) 05-06 gt's, stock, run 14.7 ish. So did I. I am Dynoed at 378 rwhp, and I run 13.3. The track is where it is at. I want to go to a sea level track and test. plus, how do you know your track is a perfect quarter mile?
Hmmmm I wonder if those cars had the 17 inchers which would help a bit... Union Grove will help me determine what I do next, I'd really like to get a 13.5 or 13.6 out of it solid at 103 mph... maybe I'm expecting too much.
I've given thought of reinstalling the stock air box and tune and base lining the car on Tuesday as well then reinstall the Tunable Induction CAI and 93 tune to see the difference.
ORIGINAL: MusiccityGT
+1 My best run in Bowling Green was a 13.4. The fastest time from the other 5 or 6 05/06 GT's was a 13.9 and the others never broke a 14. Track conditions and altitude come into play bigtime.
ORIGINAL: viking396
ORIGINAL: Fly
There's where your ET is going. With a 93 tune, I would think you could take each gear to 6500. I go through the traps at 6500 in 3rd gear running stock 18" wheels and tires and I'm only running a 91 octane tune. I think if you stretched it to 6500 before you shift, you'd see a dramatic decrease in ET.
ORIGINAL: viking396
You shift where the car makes power too, not higher and not lower unless you want to slow down. On the very last run I held out 3rd gear and my mph suffered as did ET, hanging it out further isn't going to give me 3 tenths and more mph.
Now, if someone with experience with these engines could chime in (hint Chevykiller) he can explain that if you're shifting at what you think is 6500 then your tach is off, hell maybe mine is but I think what I say is valid, an engine stock making optimal power at 5800rpms isn't going to suddenly have the ability to make power 700rpms higher without modifications to the heads.
Maybe I'm wrong but I don't think so...
Ok, I have gone to the Great Lakes Dragaway web page to use their calculators and per the calc my car with me in it weighs 3773lbs (3450, + 273 + 25lbs gas) (yes, I'm a fat SOB, what can I say) and with that weight and a trap speed of 102 from yesterday I'm putting down 313hp Union Grove Dragaway Calculator Page Link
The first calculator is supposedly the most accurate but of course this isn't gospel...
Here are my runs per the timeslips:
Run 1 all shifts at 6k
Launch 2400rpms spun 1st gear a bit
60ft = 2.242
330 = 5.961
1/8 = 9.032
MPH = 80.26
1000 = 11.657
1/4 = 13.863
MPH = 102.12
Run 2 all shifts at 6k
Launch 2400rpms felt strong less spin
60ft = 2.167
330 = 5.930
1/8 = 9.018
MPH = 79.81
1000 = 11.662
1/4 = 13.884
MPH = 101.35
Run 3 all shifts but 3rd to 4th at 6k, 3rd to 4th per my notes was at 5900
60ft = 2.159
330 = 5.931
1/8 = 9.040
MPH = 79.43
1000 = 11.687
1/4 = 13.919
MPH = 101.01
My goal is to go to Union Grove on Tuesday as I've mentioned and re-tune it Then I'll try to wing it above 6k, if it feels strong I'll hold it to 6300 and see how it runs.
Chevykiller, if you're reading this chime in on the shift points mentioned by some people.......
60ft = 2.242
330 = 5.961
1/8 = 9.032
MPH = 80.26
1000 = 11.657
1/4 = 13.863
MPH = 102.12
60ft = 2.167
330 = 5.930
1/8 = 9.018
MPH = 79.81
1000 = 11.662
1/4 = 13.884
MPH = 101.35
60ft = 2.159
330 = 5.931
1/8 = 9.040
MPH = 79.43
1000 = 11.687
1/4 = 13.919
MPH = 101.01
ORIGINAL: Fly
OK, keep shifting into 4th and I'll refrain from trying to help you. You asked a question, I tried to help. BTW, ask your tuner what VCT means.
These heads will make power at 6500 rpm without being worked, period. Mine does, as does another person that has posted on this thread. But I will suggest that it is a possibility that your tune might be a little lean (13 or higher) and that the processor might be pulling some timing resulting in your power flattening out. I would recommend checking your A/F ratio before trying the 6500 rpm shift point.
