install cost on guages & short throw?
RE: install cost on guages & short throw?
Scooter80, Yup pretty sure it's broken. Cuz when I first got it it would show aboout 10 psi vacuum at idle and then somewhere around 5-6 psi boost near redline (Lone star said it was supposed to be around 9 psi boost with pulley swap so not sure what's up with that).
Now the needle just sits there on 0. No vacuum at idle, no boost under throttle, no nothing.
Gauge might have lost power? Just a thought for something to look at.
Sorry about all the BS man. If I could advise everyone in the metroplex before they went ANYWHERE I certainly would.
The boys in Lewisville will be able to get ya right with the world. Just beware of the race schedule because they do attend events. So there will be some weekends that no one will be around because Manny will have that 1100rwhp Slobra of his flying down a track somewhere.
ORIGINAL: paco_pony
I would not drive untill I had some look at it. You could risk engine damage.
ORIGINAL: paco_pony
Anybody got an estimate on the dollars or hours (for a prof mechanic) to install a two gauge pod with a/f and boost?
How bout dollars or hours on a hurst shifter?
thanks
thanks
wow sorry to hear about all the probs. The gauge install prices are pretty hefty anywhere you gi, because it does get a little tediuos and you have to run a crap load of wiring and so forth. Most shops I've heard about charge anywhere from 200-300 for installs of the gauges ( my shop wanted somewhere around that for my 3 gauge install ) I just had them install the senders and then I ran all the wiring and vacuum line and ran all electric ( including setting gauges to my dimmer ). It took me about 3 and half hours taking my time and being anally neat about it.
Hope things work out with your tune man ... It;s hard finding a great shop - I know. I am so happy I found a place by me... can't imagine what I'd do otherwise.... Good Luck and I wouldn't go running the rpms too high until you get the tune worked out
