Strange sound from rear end around turns
Old 06-15-2006, 10:32 PM
Claytone
Claytone's Avatar
Default Strange sound from rear end around turns
OK so I have noticed this strange sound coming from my rear end when I make low speed turns, such as in a parking lot. It sounds almost like a whirring, imagine a wrrrrrrrrrrrreehhhrrrrrrrrr. Yeah. What the hell is that???????
Please dont tell me my rear end is F*CKED!!!!!
Claytone is offline
Old 06-15-2006, 10:38 PM
MusiccityGT
MusiccityGT's Avatar
Default RE: Strange sound from rear end around turns
More than likely your clutch packs in the t-lok. [:@]
Been a lot of posts on that problem.
MusiccityGT is offline
Old 06-15-2006, 11:16 PM
Rt1Rebel
Rt1Rebel's Avatar
This apparently was mistaken for a power steering problem also. I've got it.
Is it just noise, or is damage done/being done? Something that goes away after break-in? I think I can live with it as long as there is nothing actually wrong with the car other than the noise.
Rt1Rebel is offline
Old 06-15-2006, 11:46 PM
MusiccityGT
If your rear differential is making noise on turns then there is a problem that needs to be addressed under warranty. They will have to replace the clutch packs, or change the center chunk in its entirety.
Old 06-16-2006, 01:35 AM
Claytone
Claytone's Avatar
Anyone know of any "aftermarket friendly" dealerships in South Florida?????
Claytone is offline
Old 06-16-2006, 09:54 AM
Stooge
Stooge's Avatar
I'd suck out the gear oil and replace it with a good 80W140 synthetic with some trac-loc additive. This probably will solve the problem. You should change the gear oil the first 5K miles anyway as alot of wear metals are there in the oil after break in, and you really want to get that stuff out.
Stooge is offline
Old 06-20-2006, 09:09 PM
Claytone
Claytone's Avatar
Ok so I took it into Ford, after removing the CAI and reflashing back to stock. Took the tech for a drive and instantly he said it was my clutch packs. He told me to leave it with him for the day. At 2 it was done, he replaced whatever part was busted, and added additives that were lacking from the factory, which is apparently the reason for this problem. So for all you new buyers, get this additive to avoid this problem. Just ask your tech shop. I was surprised to find out that he had no problem with the lowering springs, LCA's nor the UD pulleys. Again that may have been different had I gone in for engine problems. But yeah. problem solved. easy.
Claytone is offline
Old 06-20-2006, 09:10 PM
austijc
austijc's Avatar
ORIGINAL: Claytone
Taco Bell?
austijc is offline
Old 06-20-2006, 10:18 PM
Claytone
Claytone's Avatar
Claytone is offline
Old 06-20-2006, 11:09 PM
bushbanger
bushbanger's Avatar
I was thinking power steering pump also .. What is involved with changing the clutch packs ??
bushbanger is offline
Quick Reply: Strange sound from rear end around turns
