I use it. You have to knock the bushing off of the valve cover bolt to put the bracket on. Has to be done on a vise or something simmilar that will be able to hold the bushing so you can knock out the bolt. Makes a very solid set up.
I'm using the bracket, it was easy to install. I figured I'd rather play it safe. The C&L intake is fairly heavy, so I thought the extra support was a good thing.
Did not use it on my installation. Seems stable enough without it. Did not want to remove a bolt from the valve cover at that time. Check it often, no issues. If I see something going on there I will certainly use it.
