Steeda CAI install problem
I just installed the CAi from steeda, but I am having a hard time getting the tube over it...........seems to me the stock tube is to small?? Or does it take allot of effort? Is there some trick? PLease let me know
RE: Steeda CAI install problem
Did you get the 88mm MAF or the 90mm MAF? If you got the 90mm MAF that is why the tube is difficult to get on. Use a little WD40 for a lubricant between the intake tube and the MAF and a couple of screw drivers. It will work itself on. You might teach the children in the neighborhood a couple of new words while you are doing it, but it will go. Also I might suggest making sure your hose clamp will work before you get all involved.
