Pro 5.0 Shifter
Pro 5.0 Shifter
I was flipping through some Mustang mag's and noticed that everyone of them have a huge Pro 5.0 shifter add for the 05-06GT. I am curious as to how this will help prevent missing gears. Also, my stock shifter is already pretty short - I think going any shorter would simply make it difficult as a daily driver. One question also, how difficult would this be and how long will this take to install in my driveway? This would be my very first shifter switch so I am not too familiar with it at all.
RE: Pro 5.0 Shifter
I installed a Pro 5.0 shifter on my GT about 2 months ago. It took me about 4 hours total while using a lift. It took this long because I'm not the most technically inclined person and the instructions that came with the shifter were very bad. Anyways, after installation, it was extremely difficult to get the car into 5th and Reverse. I figured it would take a little while to break it in. And finally one day 5th and Reverse was as smooth as any other gear. That's when I noticed it was hard moving the shifter left and right while braking. After taking it in to the dealership, the mechanic found that the bolt connecting the shifter to the transmission popped out and was grinding against the chassis. Well, they popped it back in and AGAIN it's hard to get into 5th and Reverse. Sorry, I'm going off on a tangent...
As a daily driver, I enjoy the Pro 5.0 shifter because it's smooth and slides into each gear without any unnecessary resistance. It seems to "click" into gear. In my case, the shifts are great until I want to get into 5th or Reverse. That's when I lean to the left to get my whole body into the shift to push the shifter to the right. I hate that (if you can't tell by now). I don't think my issue is very common, even though I've heard of a few others having this problem. I think it may be just a break-in period. Feeling the stock shifters on other 05's brings a smile to my face because the length of throw seems very long compared to mine. It almost seems too long. You will definitely get used to the feel of your new shifter. And I really do think you'll enjoy the smoother shifts and shorter throw.
RE: Pro 5.0 Shifter
ORIGINAL: hawgman
If your shifter is hard to get in to 5th and reverse it could be because you tightened the bolt that connects the shift rod to the shifter up too tight.
RE: Pro 5.0 Shifter
ORIGINAL: Maineiac
Actually, it felt the same without that bolt even in the hole. I only tightened it until it stopped too. [:@]
Did you triple check to make sure that you got the offset correct on the two bronze bushings? The large bronze bushing should go toward the drivers side. The smaller one toward the passengers side.
RE: Pro 5.0 Shifter
ORIGINAL: hawgman
OK... you are going to have to explain that one to me since the shifter won't even move the rod without the bolt being in the hole because it takes the bolt to connect the shift rod to the shifter. Without those two pieces being attached to each other, all you have is a shifter that will move in any direction.
ORIGINAL: Maineiac
RE: Pro 5.0 Shifter
Ummmm, yeah..... That really makes me want to run out there and buy one today. I thought the point was to improve shifting. If I have to lean into it with all my body weight - then I think I will stick with the stock setup. Thanks though, you just saved me $250+
RE: Pro 5.0 Shifter
Well, by the sound of it you're not aware that there are other choices for short throw shifters. From what I've read the average install usually takes about 30 minutes to an hour or so. I've had my Hurst short throw in for a few weeks now and I don't have to put any of the effort into it that's mentioned here. The throws are considerably shorter and I love the retro look of the white ball. Price is about $100 less than the competitors so IMO it's well worth it.
RE: Pro 5.0 Shifter
Well I don't know what to tell ya. Mine shifts effortlessly, and as BoidMorphs said, only took about 30 minutes to install. Have not had a minutes worth of trouble out of it. And I know a ton of people using the same shifter with no problems. But on the bright side, your one and only negative experience saved cryptic26djp $250. Sounds like he should buy you a beer.
