major low RPM lag
RE: major low RPM lag
ORIGINAL: IA_Chiefs_fan
I wonder if I'm just more easily impressed or I got a really good car. I have an Auto GT and it throws your head back against the headrest immediately. I've taken many people for a ride and I assure you that none of them were thinking, "Wow, that's really impressive... after 2500 RPMs." My car is stock except for a cat-back magnaflow, for only just a little longer.
I think the issue (and I have seen it with my car, too) is that where with some vehicles you can lug down quite a big and still have some power, these cars are pretty useless. Now maybe autos are doing this too, but if the computer is anywhere near smart it will be shifting to another gear before you really notice it.
ORIGINAL: HypromanGT
Correct me if I am wrong, but if you've got an auto and you mash on the gas, that baby's going to drop to <insert low gear here>, the RPMs are going to go to <insert high RPM here>, and the car's going to take off like a rocket. If you are mashing the pedal enough to "[throw] your head back against the headrest immediately", then I highly doubt you're at 2k RPMs for more than a split second...
Also autos have something called torque converter flash stall in their favor. The slippage in the converter will let the tach rise higher into the powerband under sudden WOT and actually help low end torque by acting like a torque multiplier.
I think it is a combo of slow reacting throttle response and poor low end torque.
Also, HP down low is a useless measure. 100 HP at 2000 rpm is actually 250 ft-lbs of torque which aint bad.
But in comparison to a modest big block.
At 2000 rpm my 451ci mopar is making approx 465 ft-lbs.
So in reality, we are still torque deficient. And that is what makes the car move at low engine speeds.
nah man its more than torque deficiency. i rode in a buddy's 5.0 when it was bone stock, it didnt lag NEARLY as bad. not even close. i know what torque deficiency is; this isn't torque deficiency. cause while our cars pale compared to huge big blocks and such, they're not exactly lacking in low end torque. theres something else goin on here. try this: get started in first gear, and then let the car slow to idle speed. floor it. see what happens. NOTHING.
you notice the lesser torque when u shift to second and floor it at like 2500 RPM. the thing that happens in first gear, thats a goddamn electronic nanny. its embarassing. some kid in a modded to high hell civic and revved for a long as time at a light, then launched. i didnt want to appear to be trying too hard, so i took off normally, then floored it. EMBARASSING. took me till the end of the intersection to take him. i had to wait like .5 second for the power to come on. its goddamn frustrating.
remember kiddies, HP=torque x RPM divided by 5252
ORIGINAL: bl1nkage
I asked this same question about a month ago, and everyone told me it was throttle lag from the drive by wire and a tuner will fix it. My tuners in the mail, so you can either take their word for it, or wait a few days and Ill let you know first hand. You have to remember our cars have an incredibly BAD tune. Everything is tuned for the average person to buy this car, its not tuned for people who want to **** their pants when they touch the gas. In my auto, even the shift rpms are incredibly low. I can be going 10 mph at 2k rpms and have it shift into second. Its stock tuned for good gas mileage and people who just want a nice looking car. Im hoping, and praying that the tuner unleashes the beast of a car that I know is deep down in there somewhere.
See if doing the following improves things:
1- Disconnect the battery's negative cable for 10 seconds, and reconnect.
2- Turn the ignition key to the ON position(not the ACC position, and do not start the engine),
and wait for the dash warning lights to go out and the chime to stop.
3- Press the gas pedal all the way down in one smooth motion(approx. 2-3 seconds to hit
the floor).
4- Quickly release the gas pedal as soon as it hits the floor.
5- Turn off the ignition, and wait 5 seconds.
6- Start the engine normally, and drive.
Steps 2-5 may have to be repeated 3 times in order for the ECU to re-train the
throttle variable switch and the throttle body servo motor.
the floor).
