BAD@SS '06 GT COMBO?
#32
RE: BAD@SS '06 GT COMBO?
ORIGINAL: jaiasmit
I did the install of the ram air intake myself. It took me about 4 hours, but I could do it again in about an hour. I made sure to take my time, and read the instructions very closely so that I got everything right.
As far as the warranty, that's a largely debated topic with all aftermarket merchandise. It's really up to the dealer you work with. If you do a search for Magnuson Moss on this board you will find tons of information on warranties and aftermarket products. The basics of the Magnuson Moss act are that simply installing a 3rd party aftermarket component cannot automatically void the factory warranty. The dealer must be able to show that the aftermarket component was the cause of the problem before they can void the warranty claim, and then they can only refuse to cover warranty work on the parts that are affected by the aftermarket component. However, you will also find some dealers that are not willing to work with you on aftermarket components even though you do have some level of protection with this act. If you run into one, you should look for another dealer. I am definitely not an expert on this issue, so you're best off to do a little more research. There is a lot of information already available on this forum.
ORIGINAL: johnnyv8
thanks for the replay jaiasmith; i just have a few more questions for you. Did you have your ford dealer put it in or did you do it ur self? and do you know if that ram air void are warr?
thanks again.
thanks again.
#33
Yeah, the ONLY reason that I chose shorties is because I didnt feel like screwing around and changing stuff on the stock H pipe. I mainly disliked the ugly stock headers that you see when you look down into the engine compartment. If I am getting the Saleen Supercharger, then I am not all that concerned over 20 more horsepower from a set of longtubes. Im not trying to build a dragster here. Just some beautification and a little performance adders maily. Thanks for the help guys!!!
KingRando
10-02-2015 08:06 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
