One foglight burned out
I have about 21,000 miles on my '06 GT one foglight has quit working (burned out). how do you change the light bulb? i have removed the radiator shroud and can't see how to get to the bulb out to replace it. what am i missing?
Thanks in advance
Thanks in advance
RE: One foglight burned out
I had this same problem, except mine went out in under 3000 miles.[:@] I have changed the bulb already. To change it, you need to pop off the plastic cover over your radiator. Just a few clips, then there are only 2 bolts/screws that you need to take out that connects to the front end. They are on either side of the car. Once you loosen them up, the grill should be loose and you have to move the top of the grill out. I couldnt squeeze the grill clips out of place to get to the bulb (and I also didn't try tooo hard), so I had to squeeze my hand back behind the grill and unscrew the light bulb and I somehow managed to get the new bulb plugged in and back in place. It will make the job much easier if you can pop the grill out and pull it out a bit to reach the bulb better. Once you have the new bulb in, just put all the screws back in place and you're set. Hope this helps.
lincolnshibuya
12-08-2015 04:37 PM
