X-pipe w/hi-flow cats
RE: X-pipe w/hi-flow cats
You can buy a x-pipe from www.brenspeed.com and keep your own cats. The Magnaflow x-pipe with cats is about 450 dollars. You can also buy a pypes x-pipe with no cats for about 160 dollars. The pypes pipe I heard rattles. The Magaflow pipe sounds good but it like the others only gives you about 5 horsepower, excluding the pypes x-pipe with no cats that gives about 8 horsepower. All these are horsepower to the wheels.
Try the bassani X pipe w/ high flow cats, comes with straight pipes as well to attach instead of the cats for those track days if you want
You can buy it here
You can buy it here
im not a fan of SLP's, but i will say this, if you do happen to get em or like em, go with an H pipe, because the slight raspyness of an X pipe really comes out with SLPs and if you drive through a rough neighborhood then people may think your commiting a drive-by
