BETTER GAS MILEAGE
RE: BETTER GAS MILEAGE
my CAI and 91 octane tune made my gas mileage go up like 2 MPG's. you cant go wrong with the CAI + Tune with the performance and the gas milage. i know its minimal, only 2 MPG's but you asked what you can do to improve so im telling you.
ORIGINAL: teaberry
EXCEPT FOR THE OBVIOUS IN DRIVING TECHNICS. WHAT ADD ON CAN I PUT ON TO INCREASE GAS MILEAGE ON MY 06 GT.
Many mods - cold air, Blower/TB increase mileage under normal circumstances as they increase the efficiency of combustion...
But, they also increase the efficiency to which fun is delivered to the driver and thus your mileage on a net basis goes down...
The Stang has a generally useless but interesting little "fuel efficiency" meter built into the dash...
I would suggest that you will save far more gas by frequently resetting your average MPG and watching the weenie-meter...
This is just not the right car if you are trying to save money on anything much less gas... (BTW - this site is horrible for the purposes of spending less money on your car - a few weeks reading this stuff and you will be convinced that a twin turbo 900HP engine does not seem all that rediculous for your 20 minute commute afterall)
P.S. BTW - it gets worse WRT to bolt-ons - many work better with higher-octane which throws savings out the window again if you have to pay 10-15% more per gallon...
If you do mostly around town stop and go driving, then smooth driving is the key for getting good mpg, e.g., press down on the gas pedal like there's an egg between your foot and the pedal when accelerating from a stop, do not rev at high rpm's in lower gears, get into high gear ASAP, drive at a steady speed whenever possible, downshift only to maintain speed when going up a grade or when passing, and let up on the gas as early as possible when anticipating a stop.
If you do mostly level highway driving, then use the cruise control, and do not roll down the windows if traveling faster than 40 mph. But if there are a lot of steep grades, then drive without cruise control and downshift when necessary to maintain speed.
And for all driving conditions, maintain the recommended tire pressures, make sure the wheels are properly aligned, keep the engine in good tune(plugs, air filter, etc.), and use the A/C only when necessary.
ORIGINAL: ski
...press down on the gas pedal like there's an egg between your foot and the pedal when accelerating from a stop, do not rev at high rpm's in lower gears, get into high gear ASAP, drive at a steady speed whenever possible, downshift only to maintain speed when going up a grade or when passing, and let up on the gas as early as possible when anticipating a stop.
Post your comulative MPG number with picture of the dash and the one with the highest # gets a public spanking...
What you are describing is cruel and unusual punishment to both car and driver... I cannot condone such activities...
Before you spend a dime bolting anything on your car - do the math on what you save in gas and how long it will take to pay for the mod...
+1 on the above, if you must save gas - don't bother mucking with the car, just drive like its dad's ferrari and he doesn't know you took it to show it off...
The best way I have found to get better gas mileage is to leave the MPG meter up on your dash. After you step on it a few times and see 13MPG, you will drive better. I can average 10MPG on a tank of gas with both hwy and town driving. ( If I leave the MPG display up)
Later
Later
