Redline Diff Oil >>>>> *.oil
My diff, when warmed up, would click and grind and squeak and scare me like it was falling apart. I had my shop put in Redline oil and there is no noise whatsoever anymore. This is the best $47 investment I have ever made. I just thought I'd pass it on...if your aftermarket diff is grinding and sounding bad whenever you make a turn (ESP if you have an Auburn diff), give some Redline oil a try before you go replacing shlt.
on a side note, my MidwestAuto plenum cover came in today...and is major sexy!
RE: Redline Diff Oil >>>>> *.oil
Redline is good stuff, their engine oils and greases are amazing. But I find that in the porsches that have transaxels prone to gear chatter their gear oil works for a while and then this out a bit after one season and the noise returns when the car is hot.
I now use swepco gear oil in the porsche and the clatter is gone and stays gone. Swepco is well known for their gear lube.
But I cant say that I have heard a peep out of the stangs diff so far.
Sleeper - If you want my recommendation from having owned 2 Auburn differentials, drain that oil NOW and rinse the diff with mineral spirits. Auburn stongly recomends against synthetic gear oils as it can and most likely will cause failure. I have had 2 Auburns fail on me and I will never use another.
In mopars, many times people have had diff problems when using synthetics with auburn and other diffs. I would call auburn. Redline will always tell you it is OK. But most of the time aubun diffs need a nice standard oil with a bottle of limited slip additive.
ORIGINAL: classj
I didnt realize you had an auburn diff sleeper. I would be very carefull as said above about the synthetic oils. OE difs seem to fair better with synthetics than the aftermarket diffs.
i appreciate the advice, however. and a side note: it DID have a nice standard oil and a bottle of limited slip additive...and the noise could be heard from almost half a block away. i will give auburn a call though and ask their recommendations. It's an auburn pro diff.
I'm a Redline and a Tufoil fan. Changed my engine and 5 Spd. fluids out at 4.6k.
Use Redline "D4" in your trans, add a 10% mix of Tufoil. www.tufoil.com
I believe mine shifts better now.
ORIGINAL: cekim
hmm - any equivalent miracle fluid recs for manual trans?
ORIGINAL: algregory
ORIGINAL: cekim
That has me excited in all the wrong ways... []
