nitrous track times
#21
RE: nitrous track times
ORIGINAL: blowngt
75 hp at the track? What a waste. First of all, if you squeeze of the line you will not hook up on street tires
#23
[quote]
[sm=bustedsign.gif]
ORIGINAL: blowngt
ORIGINAL: GTlust
The Zex kit releases the nitrous shot at wide open throttle only. How many people launch at wide open throttle?
#24
ORIGINAL: flewbyu
Hey, what is the electronic window switch for??
TPS (Throttle Positioning Sensor) -> Sends signal to turn nitrous on at full throttle -> Window switch allows signal to pass through and turn nitrous on if the RPM's are in a specific range. i.e. 3krpms - 6krpms. So if you were to have it floored at 6200 rpms about to bounce off the rev limiter, the window switch would have already turned your nitrous off even though the TPS is telling the nitrous to spray.
#25
ORIGINAL: RodeoFlyer
Sleeper - first of all you have a JLT intake and I have a K&N
second of all you are ignorant/il-informed (not to be rude) - check the big magazine article that everyone refers to when the CAI subject comes up. K&N claims a 15hp increase with NO TUNE. the magazine was surprised when their test resulted in 18 hp with NO TUNE. how bout them apples? they added a tune and only gained 3 more hp
thirdly - unlike with a supercharger, the Zex kit comes with it's own fuel management unit which distributes fuel as required. with a supercharger it's bigger injectors and the rest is up to the computer. therefore the Zex kit can be run without a tune
fourth - i fully realize the potential of a tune. i also fully realize the ramifications when the dealer sees a flash date on my computer. i have a 5 year/75000 mile warranty that i intend to keep. the Zex kit can be easily removed. at only a 75hp shot w/ it's own added fuel delivery, the engine will be plenty safe. i am only concerned with the level of performance anyone with that system has seen.
#27
yeah when you reflash your ecm, it stores a fault for communication between the ecm and guage cluster. because the two module cant talk to each while one or the other is programming. i think my new dealer ignores it because they dont care.
#28
a) i got just shy of 50rwhp with just an intake and pulleys, with the aid of a proper dyno tune, and
b) a tune will NOT, and CANNOT void your warrenty, while
c) nitrous WILL void your warrenty no matter what.
while no mod can "void" your whole warrenty, nitrous will void the warrenty on your engine, tranny, driveline, and possibly a number of other things. also, i hope to hell you get colder plugs if you dont want a tune.
i am FAR more researched than you on these new stangs (tho not an expert nor do i claim to be one), and have MUCH more hands on install and run time than you with mine. i was simply giving you an educated and valuable opinion that a tune would be the proper and mature way to approach any use of nitrous on a system as sensitive to change in conditions as our motors are. take it or leave it, but HOW DARE YOU CALL ME IGNORANT
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
09-01-2015 08:16 PM
