missed a gear...
RE: missed a gear...
ORIGINAL: 06stangGT
So i missed third the other day and reved it pretty high in neutral on accident....anyway i could have messed anything up?
thanks in advance
thanks in advance
if anything was gonna messed up, you would have known it right away btw
if you haven't had it tuned . . . it would have hit the stock rev limiter, which prevents stuff like that
You're fine. The car has a built in rev-limiter and speed limiter for just such a reason (unless you have a hand held tuner and cancelled or moved them.)
If you want to know what it feels like to hit the rev limiter, after the car has had time to warm up and you've driven it a bit. Put it in neutral and slowly press the gas. When you reach around 3500-4000 RPM the needle will start bouncing and the engine will start cutting out.
If you hit the rev limiter on accident every once in a while you're fine. I just wouldn't recommend doing it all the time. As the engine gets older, you're more like to do what's called 'floating' a valve. Not a good thing.
l miss 3 many times. l dont know whta the heck is wrong with me but yeah l do miss 3rd on this new stangs and rev the enine too.. l really dont think you messed up with anything.. dude, you are not driving a car which last a high REV.. this is a freaking mustang, you will be fine a long time, unless drive it like a stolen.
ORIGINAL: astroGT
If you're driving in 5th on the highway and you miss 3rd and go in 1st then you're screwed. The rev limiter won't help you.
ORIGINAL: astroGT
ORIGINAL: astroGT
ORIGINAL: Agleon
Tranny shoots out of the car and takes your back axel out, sending you into a spin.
ORIGINAL: astroGT
COOOOLLLLLL!!!!!
