3.31 gears
3.31 gears
New here, please help.
Looking at an 07 GT with 3.31 gears
Is there any reason to pay the extra $100 for the 3.55 gears on an 07 GT if you plan to go with 3.73 gears later on anyway?
Other than the ratio, the rearends are the same correct? as far as being limited-slip?
RE: 3.33 gears
Unless something changed for 07 the LSD is optional on the autos but standard on the manuals. 3.31 is the gear your thinking of though. Personally I say go 4.10 unless your getting an auto or going FI. If I was running 3.73 I don't think I would have noticed much of a difference. There are some charts out and about that tell you what RPM you'll be running at what speed.
RE: 3.33 gears
ORIGINAL: Timmay!!!
RE: 3.33 gears
ORIGINAL: 1QuickShortBus
The traction lock has been standard on ALL V8 Mustangs since they started putting the 8.8 in Mustangs, so you are incorrect. The only difference between the rearends is the gear ratio everything else is the same.
ORIGINAL: Timmay!!!
RE: 3.33 gears
ORIGINAL: Timmay!!!
Well I just looked at an old brochure for the 06 GT and that it said the LSD/T-Lok was optional on GTs with autos. . If the LSD and T-lok are different then my bad. I drive a manual so wasn't worried about that issue since they came standard on manauls. I've never tooken apart a diff on an auto so I don't know for sure what ford put back there.
ORIGINAL: Timmay!!!
