Burnout???
RE: Burnout???
turn off tcs. . .
rev up to 4k rpm or higher. . . dump the clutch, and immediately hit the brake enough to stop you from going forward
then let off of it after about 5 sec. . . that should be a nice one
RE: Burnout???
ORIGINAL: Black06GT40324
turn off tcs. . .
turn off tcs. . .
I like that way better.
Ive dont the right foot on both pedals when I had my Celica, but in the stang it seems a little harder/awkward.
Then I did the dump the clutch and move foot over to brake and it works like a charm.
Practice in an open empty parking lot if you need to ask how to do a burnout.
RE: Burnout???
that means your tires weren't spinning fast enough. . . rev a little higher, and when you dump, you will have to give it more gas, just don't go over redline, hold it about 5500 rpm if you can, it won't hop if its spinning fast
RE: Burnout???
I have done a burnout or two, but everyone will slam me for where I did it, but there are alot of people on here that are giving good advice on how to do it.
One thing I might add is.. if it is wheel hopping let out of it a tad and if it doesn't stop right away quit because the wheel hop will kill the car and especially the tires, it will egg shape them. I have seen it done. Practice in a wet, huge, parking lot that is deserrted.
