Lower control arm relocation brackets on the street
My Mustang is only driven on the street, but due to the engine mods I have made the stock rear control arm bushings now causing problems.
I am planning to install upper and lower poly-bushed control arms very soon.
I have read the the lower relocation brackets are good for launching, but are there any adverse effects on the handling on the street?
How about clearance problems, it seems like they are pretty low.
Thanks!
Thanks!
RE: Lower control arm relocation brackets on the street
my concern would be the amount of pre-load they are set at. CrazyAl - you have the driveshaft I see. I'm wondering how the factory u-joints would hold up with a constant pre-load?
I have the relocation brackets, (and one piece drive shaft) and I have had no problems. The suspension is "noisey" compared to stock, but that is due to the spherical ends on the LCAs.
ORIGINAL: RodeoFlyer
I don't know what you mean by pre-load. The LCA relocation brackets do not alter the pinion angle. All they do is alter the angle of the LCA. There is no "pre load"--the LENGTH of the LCA determines the pinion angle.
ORIGINAL: Herknav
Rod ends transmit noise becasue there is no rubber in them to cushion it.
The "noise" in question isn't rattling or banging. It's the typical background noise you hear in all cars--the sound of the tires rolling over the pavement. I would imagine that in the Cobra replica things would already be very lound, so it might not be noticeable.
ORIGINAL: CrazyAl
Bingo. Rod ends are definatley the best performing. They don't deflect so the proper geometry is maintained, but at the same time they can pivot smoothly so there is no bind.
Personally, I think the most practical option on a street car is the "combo" type with one rod-end and one poly bushing. My LCAs and UCA are both set up like that, and I am VERY happy with it. The noise increase over stock was minor, but the suspension hooks like glue. I have 4.30s and I have to WORK in order to spin the tires--despite this, it handles the curves wonderfully. My only enemy is gravel on the roads...
