New pics with Eibach Pro kit
RE: New pics with Eibach Pro kit
You spoiler delete guys think your so special. Did you not install the camber bolts when you did the drop? I installed the eibach bolts and adjust the camber as much as I could which isn't much. I still haven't had mine aligned and I haven't noticed any abnormal tire wear and it tracks straight as an arrow. I'll get it aligned eventually, but I think I'll be wasting my money.
You need adj. panhard bar . I can see that the rear wheel on the passenger side is under fender and if you look at the drivers rear wheel you will see that the tire sticks out from the body
Ok. So i guess you're going to have the alignment shop install them? Don't let them charge you a fortune, it really shouldn't be much more than a normall alignment. the only difference is they have to take the tires off replace the upper strut bolt with the camber bolt. Here's what my camber looks like with the eibach bolts, that's with the tops of the spindle pulled all the way outward.
ORIGINAL: jay00f4
No I didn't have them when I had the Springs installed! Mine tracks straight as an arrow also but you can see the negative camber on the front.
Why would you need a 4 wheel alignment? Unless he has an adjustable panhard bar I don't see what's to align.
ORIGINAL: toolttime
with my roush suspension caster and camber were dead on. Only toe was out by 1/2 turn on the adjuster. make sure it is a 4 wheel aligment and not 2
[quote]ORIGINAL: moosestang
Then you would see how far out the rear end is out of align. No adj. panhard bar when installing lowering springs your car is not tracking right not maybe but not right. Anybody who says that theirs is not dog tracking after is full of S###t. I know cause I used to do wheel aligments
