Lethal Perfomance 05-07 GT Ultimate Fuel System
RE: Lethal Perfomance 05-07 GT Ultimate Fuel System
Mine was plug and play. Nothing extra needed. Install the rails, run the lines, install the pump setup, plug it in and go. No need to change any fuses or change wiring. This setup supported 720rwhp on my car without issue at all. It probably would support higher, but 720 is as high as we tuned so far.
ORIGINAL: Boostaddict
Introducing the Lethal Performance 05-07 GT Ultimate Fuel System!!
This system was used on our sponsee David Beyers car to win the Modular Motor Class in Joliet, IL for the NMRA event. David's single turbo powered 05 Gt made 720rwhp on pump gas an ran times in the low 10's with this system without any shortage of fuel. Best of all is that there was no need for a modified FPDM or any other modification necessary to run this system. The Lethal Performance Ultimate Fuel System is perfect for Supercharged and Turbo applications. We will release pricing tomorrow and should be shipping these kits by the end of the week. If you have any questions about the kit or would like to order one please feel free to give us a call. We look forward to assisting you.. Thanks, Jared@Lethal
System Features:
# Dual Ford GT High Flow Fuel Pumps
# Dual -6an Outlets from the Fuel Assembly
# Billet -6an Y Block into -8an outlet
# Aeromotive High Flow Fuel Filter
# -8an Pushlock Line from the Y Block to the Fuel Rails
# Metco Motorsports High Flow Fuel Rails-Available in Clear or Polished
# XRP Fittings and hardware included
# Detailed Instructions, Clamps and Connectors included for a complete install
COST $899+ Shipping!! Add $20 for Polished Fuel Rails!!
[IMG]local://upfiles/32299/F8800030A69648C8A692910B0554B19A.jpg[/IMG]
[IMG]local://upfiles/32299/94AB52D75D604B70912B8AD8F0EA05D0.jpg[/IMG]
System Features:
running the wire from the fuel pump to the fpdm's
and to the battery..
09-10-2015 08:39 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
