driveshaft whirring?
Old 10-06-2006, 08:40 PM
moosestang
moosestang's Avatar
Default RE: driveshaft whirring?
Your pinion angle is fine i'm sure. I would swap the stock arms back on for a test drive if you really want to know what's causing the sound. The aftermarket arms could be transmitting a noise that was always there (like the drive shaft spinning), you just couldn't here it before.
ORIGINAL: Andys06GT
another ?, could it be the rear-end it out of alignment now with the adjustable panhard bar? wouldnt seem so, since the wheelbase is correct, and its centered, but its a thought. about the only one im having now...
moosestang is offline
Old 10-06-2006, 08:44 PM
CrazyAl
CrazyAl's Avatar
Edit: I screwed up in this post, assuming the OP had a 1-pc driveshaft.
Post deleted to reduce confusion.
CrazyAl is offline
Old 10-06-2006, 08:58 PM
moosestang
moosestang's Avatar
Did I miss where he said he had a 1pc driveshaft or was I just supposed to know?
ORIGINAL: CrazyAl
I'm willing to bet it's the pinion angle.
When you have a 1-pc driveshaft the angle will be quite different from stock. The measuring technique is also different.
With a 1-pc shaft you want to set the pinion flange so that it is paralell to the transmission output flange.
Old 10-06-2006, 09:05 PM
CrazyAl
CrazyAl's Avatar
Nope, my mistake! I could have sworn he said he had a 1-pc shaft in one of the earlier posts.
Sorry about the confusion, I'll edit my earlier post.
CrazyAl is offline
Old 10-06-2006, 11:14 PM
moosestang
moosestang's Avatar
I wasn't being sarcastic by the way, I actually thought you knew from a previous post.
ORIGINAL: CrazyAl
Old 10-07-2006, 12:06 AM
Mike@PowerHouse
Mike@PowerHouse's Avatar
I am going to bet that the noise is something that is found in all the new mustangs, but is only noticed once the poly bushed trailing arms are installed.
The cushy rubber bushings do an excellent job of dampening noise, but they do a terrible job of keeping the rear planted.
I am a bettin man and say that if you put the stock arms in your noise will go away.
Mike@PowerHouse is offline
Old 10-07-2006, 01:18 AM
rex7010
rex7010's Avatar
I am getting the same problem..( kind of..?? ) all stock as far as traction..
I get a whirling noise/whine when turning ONLY left ( like taking a left hand turn that you DON'T stop at ) anybody have that...???? kind of like a wheel bearing .. but doesn't sound like a wheel bearing ( I know the noise of a bad wheel bearing )
no leakage on the rims.. tires OK.. auto trans... car only has 1,700 miles on it...!!!
Thanks in advance.. now back to Andys06GT's post.. I don't want to hijack HIS thread...!!!!
Rex
rex7010 is offline
Old 10-07-2006, 07:18 AM
moosestang
moosestang's Avatar
I don't hear anything with your poly/poly LCA's, maybe i'm not listening hard enough.
ORIGINAL: Mike@PowerHouse
Old 10-07-2006, 05:10 PM
rex7010
rex7010's Avatar
le bump.. anybody..????
Rex
rex7010 is offline
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
FivePointToTheOh
09-14-2015 03:35 PM
Quick Reply: driveshaft whirring?
