Eibach sportline and Caster Camber Plates
hi all, i've order Eibach sportline springs to install in my 06 GT, i've just read on a website that with these springs, Caster Camber Plates are a must to prevent excessive tire wear will occur. how true is this?
RE: Eibach sportline and Caster Camber Plates
I installed all of the suspension mods on my car...bring it in to an alignment shop after you are done and they will tell you. I was right on with alignment, but you may be lowering your car a bit more, so you may need them. My BMR springs lowered 1.25 front and 1.75 rear. Just have the shop take a look at the alignment on the machine and they will tell you if you need them.
