Foglights
Foglights
When is it appropriate to use the GT's foglights? The owner's manual doesn't say. I've seen GTs around town at night with them on, and it was a clear night. I just wouldn't want to blind any oncoming drivers or anything. Thanks.
RE: Foglights
I only use my fogs. I have never used the reg lights once. If you want to be PC then you should only use them in fog conditions. They are mounted improperly IMO for true use anyway, they should be lower to the ground. They are bright but not brighter than the guys running hyper white bulbs. (there are many with them)
RE: Foglights
Hey use em when "you" want. A cop may pull you over and ticket you for driving at night with just the fog lights on. Get in an accident and see what happens. Sometimes being cool is being a fool.
RE: Foglights
I don't really consider them fog lights...........I consider them secondary driving lights. They offer the same luminosity as the outter lights. I usually use them by themselves when its raining or in the hours around dawn or sunset.......when there is sunlight, just not alot of it. At night, I use my outter lights only...........I think I enjoy the sleeper effect too much. The only time I'll use both sets is when visibility is low enough that one set isn't getting the job done.
So that's my system.
RE: Foglights
Yes, it's true, you can use the fog lights when there's NO fog!
The center fogs are pointed lower and if properly aligned shouldn't interfere with oncoming drivers. Can't say I've ever noticed any GTs at night yet, but I don't drive much at night any more.
If I forget to turn them on I usually end up pulling the switch out when I drive on the freeway next to one of those cement dividers. The fogs help to light up to the sides better.
RE: Foglights
It's more the direction of the light, than anything else, that defines them as fogs. I too use mine almost always when my mains are on, just for effect and added presence. I frequently drive a backwoods road that gets heavy fog almost every night, and the fogs on the GT are great. Unlike most other fogs, the ones on the GT not only illuminate the immediate roadway, but they also have just enough high-angle to put light on deer and racoons.
Personally, if the lenses were yellow, the car would look like a Tipex coming down the road...[:'(]
Gonna upgrade to some angel-eyes soon...maybe...
