Need some help (ASAP.)
Old 10-26-2006, 09:31 PM
Menace
Menace's Avatar
Default Need some help (ASAP.)
I'm installing my pulleys, and I removed the nut to the Alternator bracket on the driver's side, but there is like a stud... Before I go smacking anything, how do I get it out so I can replace it with the supplied bolt? Thanks.
Menace is offline
Old 10-26-2006, 10:01 PM
Daniel60
Daniel60's Avatar
Default RE: Need some help (ASAP.)
When my pullys were installed they took a hammer and broke it off. Yes this is the truth.
Daniel60 is offline
Old 10-26-2006, 10:36 PM
Rench
Rench's Avatar
Menace, if you have a pair of vise grips just clamp them on the end of the stud and it should come out pretty easy. It just screws out like a bolt. At least the bolt came with your pullies...............
Rench is offline
saltzy
saltzy's Avatar
I just got mine delivered and just read through the instructions. Nothing about breaking anything off... Terrific. This should be fun.
saltzy is offline
Old 10-26-2006, 11:02 PM
Menace
Menace's Avatar
I say screw the bolt they gave you.. I'm not even sure how the hell that bolt is supposed to work... Just cut off enough from the end to give the pulley room so it doesn't rub... Took a while to find a grinder, but I think someone mentioned a dremel tool should work. I started it up and there is an increase in belt noise... The belt looks like it's working find... not sure if this is normal and the belt just needs to get used to it? It doesn't sound like a squeek, it's just louder...
Menace is offline
Old 10-27-2006, 12:29 AM
cekim
cekim's Avatar
ORIGINAL: Menace
The engine bay of your car is not a place to take care of anger namagement issues
Though pulling a donor engine out of a rustbucket 70's car with a torch and an impact wrench can be cathartic...
Use vicegrips or 2 nuts tightened against eachother to pull a stud. Pulley noise can be normal depending on the bearing and/or pulley material, but just thought I would mention somewhere out there was a mention of pullies with no lubricant in the bearing (bad batch)...
I cannot remember what kit, but it is worth searching around to see if that is the source of your noise...
Also, some belts make more noise than others (cross cut vs continuous ribs) - is this a new belt or the same?
cekim is offline
Old 10-27-2006, 01:03 AM
CrazyAl
CrazyAl's Avatar
I didn't bother replacing the stud at all. Just cut the stud shorter using a cut-off disc on a dremel or a die grinder. Takes 30 seconds....
CrazyAl is offline
Old 10-27-2006, 11:21 AM
Johnnie D
Johnnie D's Avatar
the end of the stud is shapped and will take a socket, just wrench it out...i forgot what size it is buts its small...mine came right out
Johnnie D is offline
Old 10-27-2006, 01:14 PM
mustseetang
mustseetang's Avatar
A safe way to do it is it put 2 nuts on and jam them so that you can remove it like a regular bolt and it's easy... Remember 2 nuts and jam them the inside nut will act like a bolt head.
mustseetang is offline
Black Snake
07-28-2005 08:11 PM
y2jdmbfan
04-16-2005 09:01 PM
smurfman
11-01-2004 09:26 PM
Quick Reply: Need some help (ASAP.)
