Hurst Shifter??
RE: Hurst Shifter??
well, I'm not sure as mine came with the urthane bushings. Myself and another guy had, had some problems issues with a vibrating noise but mine was relpaced. I bought it through Brent from brenspeed. He replaced free of charge and its been perfect ever since. I believe the new billet one comes with the bushings also. You can go to http://www.hurst-shifters.com/
and click on the new products in the middle bottom of the page. There a PDF will open and you will see both models of shifters. Hope this helps.
RE: Hurst Shifter??
they all should come with the bushings but if I remeber right there was one site I came across that offered them seperate. If you use one of the sponsors on this site you will be ok. Brenspeed is awesome and you can't beat the customer service.
Good luck
Good luck
junior04
09-28-2015 10:53 AM
