3.55 Limited Slip
3.55 Limited Slip
What is the standard differential for the GT's? what would the difference be with a 3.55 limited slip upgrade? would fuel economy be much worse with this upgrade? Thanks in advance.
RE: 3.55 Limited Slip
ORIGINAL: LL88
I have 3.31s with a manual. I get 22 mpg in town, and have gotten as high as 29mpg in highway. This all happened with "heavy" 20s, with everything else being stock. It still pulls well. It won't launch quite as well, but you won't notice much difference past 1st gear. At least I didn't, and I test drove several GTs with 3.55s.
RE: 3.55 Limited Slip MILEAGE QUESTION
Why would the mileage rating on the window sticker give the 3.55's 25 on hwy, but only 23 on the 3.31's?
This baffles me a bit. Looking at the stickers to two cars, seemingly identical except for this difference, this is what is printed on them.
Both cars were automatics but different gear ratio.
I'm 99% sure that they are not offered on autos. That would explain why the higher gears are rated lower. From what I've seen, the manuals are rated the same mileage with both gears on the sticker.
ORIGINAL: slow07
