I know I know....do a search! I HAVE!!!!!
I've looked through all the threads I could find on shifters and haven't made up my mind yet. I also understand that a shifter is going to come down to personal preference moreso than anything else. However, I would be interested in your recommendations on my wants.
1. Shorter throw(obviously)
2. I like the notchy feel with positive gear engagement.
3. I want the rip to 3rd to be quick and easy with no chance of a miss.
4. I'll be honest...I like the slightly bent lever that angles back toward the rear.
5. I don't want to have to sweat to get it in gear either. No using two hands.
Any recommendations would be awesome, and at this point if I'm going to go with a shifter I think I've ruled out the adapter.
RE: I know I know....do a search! I HAVE!!!!!
Theyre all relatively similar, it really is personal preferance. I did have bad luck with Hurst though. The threaded portion of the shifter with the **** broke off.
-P.
-P.
Everybody I've talked to (including myself at times), likes the Saleen short throw adaptor on the stock shifter. It shortens the throw by about 30-40% or better and the feel can be adjusted somewhat depending on how much you want to torque the bolt and nut. I adjusted mine twice before I really got it to where I like it the best.
Just make sure you use plenty of a good thread locker when you get it just right.
Try this thread: https://mustangforums.com/m_1050051/tm.htm
UB10
UB10
+1 to Underbird's comments.....As far as the 2nd to 3rd throw, you might want to look at the threads pertaining to the K Member Torque limiter......
Talk to Riven. He has both the Saleen adaptor and the torque limiter.....
Mike
Mike
jessicarabbit
09-25-2015 12:41 PM
