Should I get a Hurst or Steeda Tri-Ax?
Hello everyone and Happy Turkey Day! I am tired of my stock stick and want to get something with a shorter throw to it. I know alot of people on here have both the Hurst and Steeda shifters. Is there a difference other than the look? Any benefits from one to the other? Will the dealership Natzi's have issues with this as warrenty work that might come into play?? Thanks for all the help on this site...i love it
Oh yeah, how about those Buckeyes....... [sm=drooldude.gif][sm=bounceybounce.gif][sm=yikesomg.gif][sm=wootwoot.gif]
RE: Should I get a Hurst or Steeda Tri-Ax?
I had the Ford Racing Drag Pack installed, and it came with a Hurst Shifter...I don't think that it would cause a problem, Ford Racing has one available:
Part M7210-T MSRP: $210
I like it. I haven't tried any other shifters though...
Whichever shifter you buy make sure the one you get has stops. I cannot say enough about getting one with stops to protect your shifter/tranny. On a side note I haven't heard anything bad about the steeda, well that is except its $280 price tag haha.
Att. Andrew
Att. Andrew
ORIGINAL: TElke1
Hi TElke1,
Have you considered installing Saleen's short shift kit and Steeda's poly shifter bushings? For less than $80 you can get a much shorter shift throw and firmer shift feel. You don't need to worry about damaging the transmission shift forks on the S197 tranny because the stock 3650 5-speed transmission has internal mechanical stops to protect the forks.
Actually I forgot to say Tremec recomends against installing a shifter with mechanical shift stops because they are frequently adjusted improperly and the often the cause of broken or bent shift forks. I pretty sure that they know how their transmissions work best and what third party shifters do and would follow their recomendations before buying a product with stops.
HTH
ORIGINAL: chirostang
Tri-ax is better. Go Blue!
Hi TElke1,
Drove it, hated it, drove another car with it and hated it. Noisy, vibrates and is just too stiff unless you are slamming gears on the strip, where it is perfect. Anyother time the Tri-Ax is horrible to deal with. BOTH of the guys that had Tri-Axes I drove pulled them out. One installed a Hurst, the other went with Saleen shift kit and Steeda poly shift bushings and both are much happier now.
HTH
Go with the Tri-Ax, period. If you think you want the Hurst, save yourself the money and just get the Saleen adaptor for $40 because all the Hurst is ( basically ) is a stock shifter with a shorter throw. If you want an actual shifter upgrade then get the Steeda.
ORIGINAL: TElke1
