Cost/Labor Rate for Trans removal
RE: Cost/Labor Rate for Trans removal
ORIGINAL: androdz
So you work with jet engines yet you are afraid to pull a combustion engine out? hmmm
Att. Andrew
PS: Search the internet you can get how to guides to do just about anything.
Att. Andrew
You have to remove the starter to drop the transmission? I'm planning on installing a new clutch when the time comes and I'll be dropping the transmission myself. i'll be buying some type of transmission jack for sure.
ORIGINAL: Timmay!!!
Actually F-16 motors come out in about 45 mins to an hour. If it wasn't for pain in the *** engine bay inspections you could go in and out with one in two hours. At least with a decent crew(4 people)Fairly easy. F-15 and F-22 motors are even easier.
ORIGINAL: androdz
Att. Andrew
Att. Andrew
ATt. Andrew
ORIGINAL: moosestang
ORIGINAL: androdz
Perfect next time I need to change the oil on my f-22 Ill give you a call so you can give me the run thru lol.
ATt. Andrew
ORIGINAL: Timmay!!!
ORIGINAL: androdz
Att. Andrew
Att. Andrew
ATt. Andrew
If I do it myself it should be easy since I have an auto hobby shop available with full up facilities. Lifts trans jack and all. I've done everything else on my car there except my 4.10s.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
