Missing Gears
RE: Missing Gears
Here is the scoup. They basically limit the flex of the engine and trans mounts causing less flex in the drivetrain. If anything, it makes the car rock more. You no longer will feel any movement in the shifter when you are on and off the gas. You will also get firmer shifts and more power transfered to the rear tires.
RE: Missing Gears
ORIGINAL: MusiccityGT
Let's just say it doesn't do the synchro's any good.[:@] If you want a definate fix for that issue, get yourself a CHE K-Member brace with torque limiters. $165, half an hours work, and problem solved.
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
