Tire pressure sensor
#23
RE: Tire pressure sensor
Your tires dont have to rotate for the sensors to work. The pcm reads the sensor once a minute when the car reaches 32mph. If the car is not moving the sensor goes to sleep to save the battery.If you let the air out of one tire after a minute or two the light will come on, then refill the light goes out after a little time. I put all 4 sensors in a 2 inch sealed pvc tube with a valve stem in one end set pressure to 32psi mounted it in the trunk light went out. Best way to go !!!
#24
ORIGINAL: jrm1900
That is by far the most creative solution I've seen, very nice...
ccdguy
09-19-2015 05:20 PM
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
